Discussion topic: Broadband down, Newcastle area
This message was authored by: purdey27
This has happened twice in two weeks. Test says it's fine but I have no connection at all. Tried all the recommended fixes but nothing works. Annoyed !
This message was authored by: Lou32
Re: Broadband down, Newcastle area
Same issue in Northumberland. Solid amber light for over an hour. Service checker says no issues detected and no issues in the area.
Avatar for purdey27
This has happened twice in a couple of weeks, recently upgraded but was better before !
This message was authored by: Scott1454
I'm stuck with the flashing green light - in Northumberland
This message was authored by: LaLa6
Internet down in Annalong area again. Followed all instructions stated no luck. Says my Internet is running fine when tested. But yet again its not. Think I'll change provider this is happening too often and for longer each time.
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by 7am use the below link to check to see if there are any broadband problems or outages nearby
