Discussion topic: Problem with my hub
This message was authored by: Paulamorris116
Message posted on 16 May 2026 07:18 PM
Problem with my hub
The lights on my hub are going on/off, curre tly only have a greem light on the power
Find out more
Message posted on 16 May 2026 07:53 PM
Re: Problem with my hub
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
