Discussion topic: Problem with internet
This message was authored by: Christine128
Re: Problem with internet
@Christine128
You haven't said what the problem is. If the broadband is down use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
