Discussion topic: Broadband speed
This message was authored by: jimbojones01
Broadband speed
I've just paid for fibre 500
when the engineer installed it I was getting around 600mbs.
now I am only getting between 30 and 60 mbs
Re: Broadband speed
@jimbojones01 When was it installed your new FF Upgrade, are you still using the same sky Hub as before? Did the position off the hub change by much from the two connection types! If it is a new hub then have you switched it off for 5 minutes then back on and retested at that point!
Avatar for jimbojones01
Re: Broadband speed
Same hub, same position. It worked fine when installed. Now we are only getting around 50mbs
