Discussion topic: Problem with downloading photographs
This message was authored by Gleneden5 This message was authored by: Gleneden5
Just gone with Sky Broadband after being a Sky TV customer for the last 23 years. Not sure if it was the right decision. I use a mac book and I can't seem to download photos easily. It takes forever. Thoughts ???
Re: Problem with downloading photographs
@Gleneden5
Who was your provider before? What package did you have?
How is your Macbook connected to the router?
I am NOT a Sky Employee
Gleneden5
@jamesn123 @We were with Bt for 23 years
@Gleneden5 assuming youbare using wifi run a simple internet speed test on your Macbook if that gives a lower speed than the result you get from the connection test in the My Sky app it is an issue with the wifi in your home. Wifi spreeds do vary due to the layout and construction of your home but can often be improved see Sky Help - Slow wifi
If the result is roughly the same or you are using ethernet and lower than the speed gave you at sign up then talk to. Sky.
Gleneden5
@Chrisee @Thank you. I will check that
