Discussion topic: Problem with Wifi
This message was authored by: Ap65
Problem with Wifi
Our WiFi is not working
Re: Problem with Wifi
@Ap65
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
@Ap65 Is it not working for everything, see the link below!
