Discussion topic: Problem joining Warzone Games
This message was authored by: CrawfordR
Hi
I'm looking some help, recently got sky broadband in currently have 310mbps download speed.
Warzone brought back Verdansk and yes I want to play it with my mate but I'm having real issues trying to join a game.
I'm on a pretty beefy PC and wired connection.
Other games seem fine although Youtube struggles to load 1080p video and just buffers all the time, can't get into a game of warzone.
Searches for a game saying <25ms ping then goes bit higher and then puts me into my own lobby and waits for players that never join, try joining my friends lobby and eventually kicks me out saying connection to host lost or something.
I have looked at the router and fiddled about but nothing makes any difference, in Cod it does say NAT Type Moderate so not sure if it needs to be open but I can't get it to change.
Any help would be great.
Re: Problem joining Warzone Games
@CrawfordR
Moderate NAT type is normal.
Is the wired connection direct to the hub or through something like a booster or powerline adapters?
I am NOT a Sky Employee
Avatar for CrawfordR
I know Nat moderate is normal was just trying to change it to see if it fixed the issue.
I did have this issue years ago also and I can't remember what I changed that fixed it.
yea wired Cat6 direct from router to pc
@CrawfordR
If you open up a cmd window and just type ping -t google.co.uk does it show a steady ping with no timeouts?
Yea shows
bytes=32 and time=16ms TTL=116
I try and watch a YouTube video in 1080p and just buffers
click stats for nerds and connection speed is 1570Kbps
network activity 20Kbps
buffer health 5s
@CrawfordR Run the same here ping -n 600 google.co.uk and let it do the full 10 minutes, post the four line result when it finishes.
Packets sent 600
received 600
lost 0
0% loss
minimum 15ms
maximum 17ms
average 15ms
@CrawfordR Would have preferred to see the table cut and pasted in but with the result's as you typed then you have NO major speed or latence issue....
Couple off speed test's below should you need them.
https://www.thinkbroadband.com/speedtest
https://speed.cloudflare.com/
https://www.waveform.com/tools/bufferbloat
I just don't know what the issue is, everything else seems fine
can play other games online and stream at the same time with no issues, but can't watch a 1080p YouTube video without it buffering every 10 seconds.
@CrawfordR Do you specifically think that it is a sky issue because the video buffers?
Well not sure, just don't see what else it could be
internet is quick, wired connection
WiFi seems fine
but buffers YouTube and doesn't load certain websites properly. Tried to go onto Ryanair.com and just loads
@CrawfordR
Honestly it seems more like a PC issue in this case with all the troubleshooting. Do you have another device to test YouTube and/or cod on?
