Discussion topic: Loss of internet
Message posted on 31 May 2025 05:37 PM
Loss of internet
Loosing internet, everything stops working around 4 times an hour. I have run a test and it surprisingly says all is ok!
Message posted on 31 May 2025 05:59 PM
Re: Loss of internet
@KAREN+HANSON
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
