Discussion topic: Printer suddenly wont print wirelessly
This message was authored by: TL14
How to allow Printer to bypass router filter. Printer used to print wirelessly, but now seems that the router is blocking it with a filter
Re: Printer suddenly wont print wirelessly
@TL14 there is no "printer filter" in a Sky hub as it doesn't know or care what data packets it is routing do all it needs them to be correctly addressed..
Wireless printing is notoriously flaky . Rebooting the hub the printer and the device you wish to print from which often sorts a system which has stopped working. Another tip  is to update the printers software.
