Discussion topic: Poor signal ?
Message posted on 10 Dec 2025 08:25 PM
Poor signal ?
Message posted on 11 Dec 2025 06:28 AM
Re: Poor signal ?
@IlonaTroiceanu assuming the issue isnt the Sky hub losing its broadband connection to the exchange (check the lights on the hub see https://www.sky.com/help/articles/hub-lights-explained-start) your problem is likely to be poor WiFi connectivity in your home.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
