Discussion topic: Printer Password
This message was authored by: CKAK
Printer Password
Printer will connect as its password field length max is 10 and router password minimum is 12, other than buying a new printer, barely a year old, any ideas?
Avatar for CKAK
Level 0 icon
Re: Printer Password
Not connect
@CKAK
What printer have you got ?
Avatar for CKAK
Level 0 icon
Canon TS5100
The only way around it seems  would be to change the password your broadband hub uses, this will mean setting up your other devices connected to it.
