Discussion topic: Power failure
This message was authored by: bikersteve
Message posted on 03 Jun 2024 01:25 PM
Power failure
Hi we have had a power failure and was told if this happened to contact you as the it will affect the broadband set procedure. We are currently having issues with the WiFi. Ty Steve
Find out more
Message posted on 03 Jun 2024 01:32 PM
Re: Power failure
Could you post your hub stats
This message was authored by: D12r2d2
Message posted on 03 Jun 2024 01:43 PM
Re: Power failure
Hi. We have had exactly the same now other device effected just the sky hub. No power going I to it happend around 1.25 to 1.30pm. Can not get power back into the hub have tried different plugs. Basically the broadband hub has died.
Message posted on 03 Jun 2024 01:45 PM
Re: Power failure
Hi. We have had exactly the same now other device effected just the sky hub. No power going I to it happend around 1.25 to 1.30pm. Can not get power back into the hub have tried different plugs. Basically the broadband hub has died. @bikersteve.
