Discussion topic: Hi, I entered the wrong postcode
This message was authored by: Holly42
I ordered to the wrong postcode  would should I do
Re: Hi, I entered the wrong postcode
Are you trying to place an order ?
If so and the order has gone through then give Sky a call about this.
150 is the free number to use from a Sky Mobile or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
https://www.sky.com/help/home
When you do call say nothing when the bot speaks to you about what your call is about as it should then route you to somebody.
