Discussion topic: Possible new customer - Sky Q question
Message posted on 31 Mar 2024 04:07 PM
I'm looking at Sky Q and Sky FTTP broadband.
Is there any reason why I can't use my own router instead the Sky one?
Message posted on 31 Mar 2024 04:13 PM
Re: Possible new customer - Sky Q question
Most asus rt ax routers work with sky however its best to use an ethernet cable for sky q
Message posted on 31 Mar 2024 04:22 PM
Thanks. I have a professional grade router which will work with Openreach FTTP, and I would be connecting the Sky Q by ethernet.
I just wanted to be sure that I could replace the Sky router with my own.
Message posted on 31 Mar 2024 04:28 PM
What make and model ? Always like to keep up to date with compatible routers
Message posted on 31 Mar 2024 05:09 PM
DrayTek. Mine is currently a Vigor 2926, but they have several other models that will do the same job.
Message posted on 02 Apr 2024 02:00 PM
As long as you dont want to use Sky VOIP & your router supports DHCP Option 61 then your fine
