6
This discussion topic has been answered Discussion topic: Possible MAP-T issue?
This message was authored by: FibreFodder
Current setup, stopped working today:
Service: FTTP (900/100).
Router: Ubiquiti UDM-SE.
Config: No DHCP option 61 + IPv6 disabled. When I moved to Sky (30 July 2026), this setup worked, no tinkering required.
Line health: Very good until a few days ago, noted 5-8% packet loss. Earlier today the connection dropped and now the UDM-SE cannot connect.
ONT: Power and PON are solid green, no LAN activity.
Fault diagnosis, so far:
  1. Powered off the ONT for 10+ mins.
  2. Performed a factory reset of the ONT.
  3. Restarted the UDM-SE.
  4. Plugged in the Sky Hub Max 6 and it connects, Power/PON/LAN all green on ONT.
  5. On the Sky Hub I noticed the WAN connection is set to MAP-T (1:8 I think).
Any suggestions on how to fix/fault find are most welcome!
TIA
Avatar for FibreFodder
This message was authored by: FibreFodder Answer
Re: Possible MAP-T issue?
Often, it’s something simple not fandango complicated … faulty network cable between the ONT and router. 😂
Thank you to the folks who replied.
@FibreFodder
Has there been a Ubiquiti update?
They do love to break things....
I know what you mean! 😉
(UDM-SE) Autoupdate is disabled and I usually wait a few weeks before applying updates. I haven't done one in a couple of weeks.
@FibreFodder for a router to be offered a MAP-T connection it must advertise support for DHCPv6 Option95 which the Sky Maxhub does. Ubquiti, bless them, managed to advertise that support but forgot to actually program their routers correctly. This started roughly 10 years ago but was finally fixed in a firmware release around two years ago so unless you have flashed so early firmware this should not be an issue.
I would check that you have correctly set the Ubquiti unit to use DHCPv6 PD with IP6 enabled. Thst set up is supported by all but 20% of Sky's Openreach connections. If you are unlucky you will require to use DHCPv4 Option 61.
@TimmyBGood , @Chrisee , Thank you both for the replies.
I'll try DHCP option 61. Although the connection has worked without it until today. I'll report back with the results.
Config
VLAN ID: Unchecked (disabled).
MAC Address Clone: Unchecked
Smart Queues: Unchecked
IGMP Proxy: Unchecked
UPnP: Unchecked
IPv4 Config
DHCP: Enabled
DHCP Client Option: 61
DHCP Client Option value: anything@skydsl|password
Auto DNS Server: Enabled
IPv6 Config
DHCPv6: Enabled
Prefix Designation Size (PD): 56 (auto box unchecked).
ONT Power cycled.
Same result, no connection.
