Discussion topic: Port forwarding not working on Sky Max Hub
Message posted on 31 Dec 2025 10:53 AM
Re: Port forwarding not working on Sky Max Hub
Strange enough, even i have started having the issues with port forwarding which i tested last worked fine in September and now no longer works, no matter what i try.
Looks like i am not alone and i am not even on MAPT too as its been turned off for me on m request.
I am sure this has somethig to do with the port forwarding rules being done by the mysky app as i had noticed that when it stopped working, none of my rules were present and weired enough that the IP had on resservation on the skymax hub webpage was showing different to the myskyapp and based on recomendation from another user in this forum, i changed the ip to what the mysky app sees the IP as but still the issue persist.
Message posted on 31 Dec 2025 07:49 PM
has any one found any solution as looks like its now nearly 2 months and no resolution yet. I completely believe the issue is the commuication between myskyapp and the hub. Its really frustrating how long this issue is ongoing
