Discussion topic: Internet connection lost
This message was authored by: Kybele
Hi,
Our internet connection is gone an hour ago. We folllowed trouble shooting steps, but still no luck.  This is really frustrating thing to experience in thw new years eve night! Please help. Thanks in advance.
Re: Internet connection lost
@Kybele
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
