Discussion topic: Port Forwarding Issues
This message was authored by: SavaloyR0cks
Hey there sky members, I have been having issues with port forwarding. It used to always work fine but has stopped recently. "Sky Hub -> Security -> Services" Does not seem to work and doesnt show open on https://www.yougetsignal.com/tools/open-ports/ ect
Re: Port Forwarding Issues
@SavaloyR0cks first point that test requires the application to be running on the device you have forwarded to answer the probe. Check the settings in the Sky hub's web interface as it is possible that the hub has lost the change as very occasionally a firmware upgrade resets the settings.
