2
This discussion topic has been answered Discussion topic: Port Forwarding Hub 6
This message was authored by: concatenatious
Hello. I would like to access port forwarding features, however I can't find them. The control panel points to using 'My Sky' app, but I cannot find the option. If it is 'not yet available' as I have read elsewhere, do I have other options?
This message was authored by: jamesn123 Answer
Re: Port Forwarding Hub 6
Hi @concatenatious
Do you not see the settings in the My Sky app? Sometimes it can take a day or two to show in the app after you receive the max hub
I am NOT a Sky Employee
Hi @concatenatious
Avatar for concatenatious
@jamesn123 wrote:
Hi @concatenatious
I just checked today and yes, it shows up. Thank you so much.
Wish it was still available via the control panel (or Gateway if that's the correct name), I don't see it's exclusion as a benefit to anyone.
