Discussion topic: Poor wifi
This message was authored by: Graham2014
Poor wifi
Just received a broadband upgrade with a new hub to get better Wi-Fi coverage around the house. Have a small house and Wi-Fi coverage still poor.
Re: Poor wifi
@Graham2014 improving speed to the hub will necessarily improve speeds over wifi in your home. Small properties with solid internal walls can be more difficult to network than larger properties with partition walls.
Firstly check the hub is in the best possible position which is as central as possible out in the open on a surface so the WiFi signals are not
blocked by radiators etc. After that consider getting a booster if as part of your upgrade you bought Sky's WiFi Max bundlle Sky will send out a matched extender pod if you call and ask for one.
Re: Poor wifi
@Graham2014 See also if the sky help does anything for you, it's linked below but @Chrisee has covered the points!
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
