Discussion topic: SKY Broadband - not able to download any apps in LG TV
Message posted on 16 Apr 2025 08:57 PM
iam new Customer to sky broadband - not able to download apps like nextflix, infact any apps in my TV when connected to sky braodband.
i have connected to my TV using my mobile hotspot and able to download but when i try to use the app connecting back with sky braodband its not working / launching the app.
tv is connected with eternet so no WIFI issues
Message posted on 16 Apr 2025 09:51 PM
Re: SKY Broadband - not able to download any apps in LG TV
Try adjusting your broadband shield settings:
https://www.sky.com/myaccount/bb-and-talk/broadband-shield
You can also do this via the MySky app.
Message posted on 16 Apr 2025 10:02 PM
Message posted on 20 Nov 2025 02:35 PM
Hi,
I have the same problem. My LG TV won't download or update any apps. However, when I connect it to my mobile phone's data connection, there's no problem.
I'm a new Sky Broadband customer. I spoke to customer services, but the problem wasn't resolved.
I've tried everything. I even reset the TV, but it seems there's a problem with the broadband network.
Have you found a solution?
Message posted on 20 Nov 2025 03:15 PM
@kerem1 when you have downloaded apps using the hotspot can you stream video say in the BBC iPlayer app? If you can then it points to an issue with LG's servers it would help if you can pist the TV model number and the colour of your hub.
If you can't stream and other devices are connecting normally it sounds likeca network configuration issue Go into the TV's settings find the Connection menu and click on the entry for WiFi or wired depending ion which you are using. That should open a screen with a line for IP address what do you see?
Message posted on 20 Nov 2025 03:39 PM
Hi Chrisee,
Thanks for your message.
Let me give more details about your questions and background.
Previously i was using different broadband and TV hadnt this issue. it was normal. Sky broadband set up yesterday and i realised the issue.
Streaming is ok. On netflix or youtube, all contents are working fine. the only issue is to download apps or updating them while tv connected to sky network. also there is no issue with other devices. i can stream and download apps from other devices using sky network. its so strange that its just related with TV and happened with sky broadband set up.
I reset TV. changed DNS to 8.8.8.8 and 1.1.1.1.
Disabled/enabled IPV6
I connected TV to modem with Ethernet cable.
I unplugged tv and hold power button to reset caches or something else per the instructions that i found online.
LG UT81 65" AI UHD 4K Smart TV -Black | 65UT81006LA.AEK
Sky hub is black one.
IP is 192.168.0.15
Tv country is set correctly, Ireland.
I hope the informations help
Thanks in advance
