Discussion topic: Poor wifi
This message was authored by: Cat1-
Poor wifi
Hi I've been having alot of issues with the wifi connection and I'm having to use my data to connect
Re: Poor wifi
@Cat1- is the issue with the Sky hub's connection to Sky or slow WiFi in your home. Similar symptoms but totally different solution.
You can check thecspeed to your hub by running the service checker in the My Sky app clicking on the broadbsnd link which should give you the current speed, the recent hiistory and the guaranteed speed for you line. If thecspedd is too low Sky should het Openreach to check the line.
Slow wifi in your home is unfortunately not something Sky can control its often down to the layout and type of construction of your home. Many homes need more than a single wifi sourcecto give reasonable wifi in every room.
This message was authored by: JayneW175
Re: Poor wifi
Hi, I am having the same issues, and I am sat in the same room as my router.
I am also getting problems with meetings freezing on me
