Discussion topic: Poor wifi speed
This message was authored by: IvanPetkov
Message posted on 30 Jul 2026 08:08 PM
Poor wifi speed
My firestick connected to my bedroom has very poor wifi since I switched to SKY
Find out more
Message posted on 30 Jul 2026 08:24 PM
Re: Poor wifi speed
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
