Discussion topic: Poor streaming
This message was authored by: GJA9006
Poor streaming
Everytime I try to watch disney+ or amazon prime they buffer every 10 to 50 seconds
Re: Poor streaming
@GJA9006 to stream video you need a strong wifi signal or use ethernet this is especially true if streaming in UHD. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
