Discussion topic: Poor sognal
Message posted on 12 Jun 2026 09:56 AM
Poor sognal
Thought changing to sky all our problems would be solved . No , still slow broadband , you use all your data on your phone , cause the internet drops out .poor service
Message posted on 12 Jun 2026 10:15 AM
Re: Poor sognal
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
