Discussion topic: Poor signal
This message was authored by: Alixd
Message posted on 07 Aug 2026 04:55 PM
Poor signal
Our internet is very poor. As soon as we go upstairs we loose connection. It wasn't like this in our last property
Find out more
Message posted on 07 Aug 2026 05:17 PM
Re: Poor signal
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
