Discussion topic: New Router. Quick way to connect 25 plus things
Message posted on 07 Aug 2026 04:18 PM
I've been told to log into your new router's admin settings and change the Wi-Fi name (SSID) and password to match your old router's name and password
How do I know the passwords????
Message posted on 07 Aug 2026 04:23 PM
Re: New Router. Quick way to connect 25 plus things
It should printed on the hub itself and it is also on the card that came with it.
Message posted on 07 Aug 2026 04:25 PM
@kerryb12 wrote:I've been told to log into your new router's admin settings and change the Wi-Fi name (SSID) and password to match your old router's name and password
It's not the individual passwords.
To make a move to a new hub easier, often people change the WiFi SSID (e.g. SKY3865TY) and the WiFi password to the same one the old hub used. All devices will then automatically reconnect.
sky Q | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 07 Aug 2026 04:32 PM
@kerryb12 I have been doing this for years and Inhoavecforgotten which old Sky hub the details came from which are currently connecting my devices to my third party WiFi. If you have lost thecdetails most devices like a phone can show you the WiFi passwordvthey are using. Remember to changecboth the SSID (network name) and ghe password on hour new hub.
