Discussion topic: Poor signal
This message was authored by: Lealea82
Message posted on 07 Jul 2026 09:08 PM
Poor signal
My sons ps5 has no signal nor does his gaming pc
Find out more
Message posted on 07 Jul 2026 10:17 PM
Re: Poor signal
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
