Discussion topic: Poor signal
Message posted on 11 Apr 2025 10:39 AM
Poor signal
I have sky glass and the signal from broadband is not enough to keep my sky glass tv on
Message posted on 11 Apr 2025 10:43 AM
Re: Poor signal
Your post has been removed as you've included what appears to be your email address on a public forum. It should return once edited by staff.
Message posted on 11 Apr 2025 02:03 PM
Re: Poor signal
What is your broadband speed ? And what other devices do you have connected to the Internet, sky glass needs a minimum of 25mps for hd channels and a minimum of 35mps to watch in uhd channels, you could use the Netflix app open go to the help at the bottom open that go to check your network and click on that it will tell you what speed your tv is getting
