Discussion topic: Poor signal on devices
This message was authored by: SidraS1
the signal is not steady and out ring door bell often fail as there is apparently poor signal.
Re: Poor signal on devices
@SidraS1
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
