Discussion topic: Poor signal in certain location of house
This message was authored by: sbhatt
We have newly installed superfast broadband however certain part of my home has very poor connection. Very disappointed. Donot know what can be done to strenghten the signal. Can sky help. Please call me or contact me if only you can resolve the issue.
Re: Poor signal in certain location of house
@sbhatt  We're fellow current here not sky support so no one will contact you as nobody knows who you are
you will need to call Sky directly about this, one possible solution is to ask them about WiFi boosters
Click on the need more help drop down at the very bottom of the link below to reveal an 0333 number if your in uk
If in ROI using the same link change the flag in bottom right hand corner and refresh the link before following above instructions to reveal an 0818 number
https://www.sky.com/help/home#M1014
or if you have sky mobile/talk call 150 Calls to Sky Customer Services from your Sky Talk landline phone or a Sky mobile are free
The start will be automated which may try to send you here to the forum or suggest you receiving a text. Stay on the line as long as possible and don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for the next available agent.
