Discussion topic: Poor download speed
Message posted on 06 Dec 2024 07:10 PM
Poor download speed
Message posted on 07 Dec 2024 07:59 AM
Re: Poor download speed
@Shonah if you have a full fibre installation it is unlikely thst speeds are affected by poor workmanship as thesecconnections either work or they dont. If you are concerned about how the install was done call Sky and theyvare likely to send someone to inspect it.
An internet speedtest returnscthe slowest part of the transfer which is often the wifi connection between the hub and your device. If you are close to the hub you should get the full speed but moveca couple of rooms away speeds drop. The best way to measure speed is on s device connected to tge hub byan etgernet cable.
