Discussion topic: Poor connection
This message was authored by: TheRealKTM
Poor connection
Hello, I have just moved to sky, and the connection keeps dropping out about 3-6 times every day. I've run through all the tests and it's not finding anything. What can I do please
Re: Poor connection
@TheRealKTM
Do you have a weak wifi signal throughout your home ?
Avatar for TheRealKTM
Re: Poor connection
No, I have a really good signal throughout the home, and the area where keeps dropping always has full signal,
Thank you for your reply
Re: Poor connection
@TheRealKTM
If you have run the line test and it has found no issue then all you can do is to call Sky to see what they say.
