Discussion topic: Poor connection to work laptop at home
Message posted on 12 Jun 2025 09:48 AM
Message posted on 12 Jun 2025 09:52 AM
							Re: Poor connection to work laptop at home
@JankaF You may just wish to try getting your laptop closer to the hub to see if it improves.
Message posted on 12 Jun 2025 09:56 AM
Hi, its imposing, engineers instaled router in kitchen. All other devices are ok. This issue happened only in last few weeks
Message posted on 12 Jun 2025 09:59 AM
@JankaF As you say everything is fine for all the other devices, then your laptop has the issue with how good the wireless signal is!
Message posted on 12 Jun 2025 10:01 AM
Laptop has been checked by company IT once working from home, said is wifi connection issue
Message posted on 12 Jun 2025 10:30 AM
@JankaF From your response to the posting, was fine, not working now, everything else is ok, only the laptop over the last 3 weeks, so with everything else working ok, and the laptop only it's something to do with the laptop, or it just does not like the hub. Remove and forget the wireless connection that the laprop has to the hub. Re-boot the laptop once you have removed it, after the laptop restart's then add the wireless connection and it's password back on your laptop. See how that goes!
