Discussion topic: Poor WiFi
This message was authored by: abbdee
Poor WiFi
We switched to Sky but WiFi doesn't feel fast and is often quite clunky/intermittent. All of our devices that use WiFi, phones, laptops, Alexa devices, yoto players etc are noticeably worse than with our previous provider that was meant to be slower download speed.
Re: Poor WiFi
On these devices do they show a good wifi signal or is it pretty weak ?
Avatar for abbdee
Re: Poor WiFi
pretty weak
Re: Poor WiFi
@abbdee
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
