Discussion topic: Poor WiFi
Message posted on 14 Mar 2025 07:51 PM
Poor WiFi
Unable to connect a device within my home that has previously connected
Message posted on 15 Mar 2025 07:51 AM
Re: Poor WiFi
@KT82 many possible reasons from an issue with the device but most common issue is its out of range of your Sky hub.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
