3
This discussion topic has been answered Discussion topic: Poor WiFi
This message was authored by: Rich1664
Poor WiFi
The sky WiFi promise is not being delivered throughout my house and I am unable to find contact details to flag this with the Sky Broadband team direct. What can I do to improve the WiFi signal, so that every room in my house is covered - as per the sky guarantee ?
Re: Poor WiFi
@Rich1664 you need to read the guarantee all custommers get see https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
as it doesn't say what I think you believe. If you have bought one of the two add-ons like Sky WiFi Max then Sky will provide extenders as explained here https://www.sky.com/help/articles/sky-wifi-max
Alternatively you can buy and use your own WiFi equipment the choice is yours.
Re: Poor WiFi
Avatar for Rich1664
Re: Poor WiFi
Chrisee - thanks for the reply and yes, you were quite right. I eventually got through to the correct dept at Sky, to then amend my package. Which now includes WiFi MAX.
Fingers crossed that it works !!
This message was authored by: Simongti
Re: Poor WiFi
Still having issues with devices stopping and buffering never had the issues like this on the old system worked well just slow.
please sort this
