Discussion topic: Poor WiFi.
Message posted on 07 Jan 2025 05:08 PM
Poor WiFi.
My WiFi is terrible. I've checked it on fast.com and it's 1.3mbps. I can't connect external cameras or security lights to it and my phone signal keeps cutting out.
Message posted on 07 Jan 2025 05:17 PM
Re: Poor WiFi.
Which router do you have? Have you tested the speed via ethernet?
Message posted on 07 Jan 2025 05:22 PM
Re: Poor WiFi.
Hi there. Yes my connection is hard wired as the signal wasn't strong enough for the wireless connection!!
Message posted on 07 Jan 2025 05:31 PM
Re: Poor WiFi.
Which Sky hub do you have? What speed package are you on?
Message posted on 07 Jan 2025 07:07 PM
Re: Poor WiFi.
I have the Sky puk on stream with their increased mega package.
Message posted on 09 Jan 2025 12:08 PM
Re: Poor WiFi.
Okay that doesnt seem right. Do other devices test just as slow? Ehernet speeds should be in line with your package so 80, 150, 300, 500 or 1000mbps
