Discussion topic: Poor WiFi speed
This message was authored by: KellyGraham
Message posted on 25 Apr 2026 05:29 PM
Poor WiFi speed
The WiFi speed is so bad that the tv puck is not working
Find out more
Message posted on 25 Apr 2026 05:31 PM
Re: Poor WiFi speed
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
