Discussion topic: Poor WiFi speed and dropping off all time
Message posted on 22 Mar 2025 12:35 PM
Message posted on 22 Mar 2025 01:25 PM
Re: Poor WiFi speed and dropping off all time
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 23 Mar 2025 04:27 PM
Message posted on 24 Mar 2025 08:10 AM
@JohnConstant increasing speed to your hub is not going to necessarily increase speed to your devices if the limitation is the speed of the WiFi signal in your home.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
