Discussion topic: Poor WiFi coverage
This message was authored by: Laun
Message posted on 08 Jun 2026 07:35 PM
Poor WiFi coverage
Hi. My wifi reception is bad in my bedroom upstairs. I need a booster to put upstairs.
Find out more
Message posted on 08 Jun 2026 07:38 PM
Re: Poor WiFi coverage
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
