Discussion topic: Poor WiFi connection
This message was authored by: ILG
Message posted on 22 Dec 2025 04:41 PM
I'm have a poor wifi signal in some parts of the house and sometime the devices drop from the poor connection.
are you able to provide a wifi booster?
Find out more
Message posted on 22 Dec 2025 04:59 PM
Re: Poor WiFi connection
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
