Discussion topic: Poor WiFi connection
This message was authored by: Leinad991
Message posted on 24 Oct 2025 10:54 AM
My wifi has been playing up for about a week, the connection on my Ps5 is really bad showing high ping and disconnecting regularly, my laptop isn't as bad but my work portal is closing every now and then.
the wifi checker shows nothing wrong but that's incorrect of course.
i have reset the wifi and this has only made it worse.
Message posted on 24 Oct 2025 12:16 PM
Re: Poor WiFi connection
@Leinad991 If you are not having any joy, then call sky and have them run a diagnostic from that end, you will need to be at home when you do it though!
