13 Mar 2025 03:42 PM
Hi, l am having issues with the Broadband upstairs. When l first had sky installed, it worked really well, but now doesn't
13 Mar 2025 04:11 PM
Posted by a Superuser, not a Sky employee. Find out more@Btoadband Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
