Discussion topic: Poor Router Performance
This message was authored by: Skymat
I have recently joined SKy Broadband however the router performance is awful unless you are in the same room Sitting in the room immediately above the router the speed drops to around 55Mbps from 900 in the same room. The room's diagonally above the router, speed drops to single figures. I have just left Virgin and had no issues at all with speed in any room in the house. This router is not fit for purpose
Avatar for Skymat
Level 0 icon
Re: Poor Router Performance
Some great spelling and grammar 🙈, however with no edit option I guess it's there to stay!
@Skymat Guess you got the white sky Max from sky, what did you have from VM?
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
then if you need below for adjusting the sky Max hub, start with the wpa3-t down to wpa2-psk advanced wireless settings, see the link about that
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
