Discussion topic: Please help
This message was authored by: XShannon94x
Please help
My broadband isnt working iv tried all the reset and restart options but nothing is helping it. It says im connected to the WiFi but not the Internet and the app is saying everything is ok and there isn't an issue in my area or with my set up
Plz help
Re: Please help
@XShannon94x
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband still isn’t working after 7am and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
