16
This discussion topic has been answered Discussion topic: Please help urgent!
This message was authored by: SNC20
Please help urgent!
I unplugged 2 of the cables as my husband asked me to reset the internet, they were both plugged back in the correct slots now it's saying no WiFi and the voice light is orange? I've plugged them back in the correct slots and nothing appears to be broken etc but the WiFi won't come back 😭
Avatar for SNC20
This message was authored by: SNC20 Answer
Re: Please help urgent!
@JimM1 it's fixed since I put it in the purple slot! I feel so silly, I obviously didn't realise I'd unplugged it from the purple slot when I popped it back in as I wasn't properly looking! I did think it was strange that it was in the italia slot but as it didn't fit in the uk one I thought that must be where I unplugged it 😂 thank you for taking the time to reply and help, it's very much appreciated!
@SNC20 Do you have the no internet and voice light error or do you say that the wifi light is the problem. see the link for lights!
Avatar for SNC20
Thank you for your response. We have an orange light for voice a green light for power and a green light for WiFi but no light for internet! All the cables are plugged back in the correct sockets so I'm not sure why it's not working? Online tests say connections are working etc.
@SNC20
What was the purpose of the initial reset?
Avatar for SNC20
Husband was playing fifa told me to reset as it was being slow and lagging? TVs and children's tablets were working ok and so was phone WiFi. I need to try and fix it asap as we can't watch tv until it's fixed as we stream everything via the internet 😭
@SNC20 Say where the cables are plugged into on the back, if you are Full Fibre cable is in port 4 marked wan to the ONT lan, if you are part fibre then the cable is in the purple connector marked DSL and connected other end to the Phone master socket either direct to it or through a ADSL filter.
Just double check that you have pushed them home fully and they clicked into place. Link below about connecting up a new hub!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Avatar for SNC20
Sorry I'm not technical at all 🙈 there's an orange cable in slot 1, a grey cable in slot 2 the 12v power cable and then our phone cable plugs into the socket that says Italia/ROI. I'm pretty sure we don't have fibre on our street yet and I only know that as a neighbour told me we're getting it later in the year.
Avatar for SNC20
@JimM1 @We have a purple slot but it's not DSL, I'm sure I didn't unplug it from there, should I try it in that slot?
@SNC20 NO it only plugs into that socket if you have the old cable to a Master Phone socket..
If you have full fibre speeds upto the 900Mb/s then port 4 wan, that cable will never fit in the purple socket anyway!
see the link post 6 shows you how to connect it all!
Avatar for SNC20
Lesson here is not to unplug cables, to reset a hub you can do that in the hub menus or power on & off at the mains, no need to be pulling cables out here & there.
Avatar for SNC20
Thanks - I couldn't reach the mains plug hence why I pulled out the cable.
@SNC20 No problems good you are back working, kids will be happy at least. Picture on the phone is always good to have should you ever want to do it again!👍
Avatar for SNC20
@JimM1 Definitely! Let's just say I'll make sure my husband re-sets it next time! So grateful for your time and help with my very silly mistake 🙈 thank you again!
This message was authored by: patriciaDaniels
need help
