Discussion topic: Please Help - cannot connect to SonicWall VPN, Sky WiFi Max hub seems to be the issue
This message was authored by: JAX474
Re: Please Help - cannot connect to SonicWall VPN, Sky WiFi Max hub seems to be the issue
Yes we are using a white sky max hub
@JAX474
OK: in that case the suspicion would be Map-T, so I'll escalate your post.
@TimmyBGood  Thank you
@TimmyBGood Any idea how long it usually takes for someone at Sky to reach out?
@JAX474
I'd hope within 24 hours.
@TimmyBGood I have still not had any further information from Sky since our interaction on Wednesday morning. I am not sure what else to do to try to escalate this.
@JAX474
I've just marked your latest post for escalation to see if that works this time.
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @JAX474.
This message was authored by: KevNewMedia
Posted by a Sky employee
Hi Everyone
Thank you so much for bringing this problem with Sonic Wall to our attention.
I'm sorry it's taken some time to get to this stage.  We've been working on the issue behind the scenes and are able to provide a temporary solution, whilst we work on a permanent fix.
Thanks again for all of your help in providing the information we've requested.
Kev
Community Manager
This message was authored by: Green301
Hi @KevNewMedia ,
I am having the same issue. Is it possible for you to provide me with the temporary solution?
This message was authored by: Lisa-P1987
Hi there Green301 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Lisa - Sky Tech Team Expert
This message was authored by: ARH2
Hiya, new Sky customer also using a white sky max hub. Since setting up I can no longer connect to my work's VPN. My work's IT support have tried all various fixes mentioned around the forum for VPN issues and then found this thread. Can I request the switch to 1:1 mapping please.
Please can this be escalated urgently as I need to access for work.
Hi there ARH2  I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Benijones
Hi @TimmyBGood  @Mr+Flibbles+86 , I am having issues connecting to my SonicWall IPSec VPN for work. I.T. has confirmed that the MTU and fragmentation options are set correctly. I.T. suggests that the issue is due to MAP-T. Can you help me fix this issue?
This message was authored by: AlexMiller
We are having the same issue.  Always used sky in previous addresses however we have just moved and set up with a sky max hub and we can't now access sonic wall for home working which is a major issue.
Works IT have confirmed that the issue will lie with the Map T config
we called sky today but like myself the girl in the phone had absolutely no idea what Map T was or how to help.
can we be escalated to speak to someone that could help with this issue.
Alex
