06 Feb 2025 06:12 AM
Router is close ? What is happening
06 Feb 2025 06:42 AM
Posted by a Superuser, not a Sky employee. Find out more@Molino-1 what speed is your hub vonnected at and if networked by WiFi what solid objects does the signal have to pass through to the Playstation?. Also what are you using to measure the speeds as some gaming sites report in Megabytes per second (MB/s) rather thsn Megabits per second (Mb/s) given there are 8 bits in a byte 34MB/s is 272Mb/s.
06 Feb 2025 03:35 PM
I'm running 134 Mps and one standard living room door the router is in the hall way the playstion is in the living room there is probably 5 meters between the router and the Ps thanks for your reply
06 Feb 2025 03:36 PM
Using the plantation its self there was lots of lag in the game that's why I checks it's really bad and slow
