Discussion topic: Wi fi drops out daily. Tried all the suggested fixes and I have sky boost and sky app shows everyth.
This message was authored by: Fh8
Broadband dropping once/twice a day. Sky boost installed , followed all the suggested remedies, no improvement. Checker shows all good even when to screen message shows no broadband connection
Re: Wi fi drops out daily. Tried all the suggested fixes and I have sky boost and sky app shows ever
@Fh8
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
